Insulation Material can not get mapped Value in OPIM.
Below picture is in OPM, Material is "Fiber Glass"..
Below is in IsoMetric,value is "FIBER_GLASS", expected to be mapped value "Fiber Glass".
Please follow the steps below to show Insulation material as "Fiber Glass" rather than FIBER_GLASS:
1. Launch Class Editor and load OpenPlant_3D schema supplemented with OpenPlant_3D_Supplemental_Modeling schema.
2. Go to PIPE class and select INSULATION property in properties tab.
3. Click Override button to enable the custom attributes for editing.
4. In the Extend Type custom attribute, change the Name field to LOOKUP_VALUE_MAP_USE_DISPLAY_LABEL.
5. Save the changes in schema.
6. Close OpenPlant Modeler and launch again.
7. Open the same model, right click on the component and select Modify component.
8. Re-set the Insulation Material for that component to Fiber Glass and save the changes.
9. Re-Generate the Iso-sheet and publish the I-model.
10. Load the I-model in OPIM and create an isometric drawing.
11. Check the Insulation material field in component tag.
You can also refer to the below link:
http://communities.bentley.com/products/plant/design___engineering/w/plant_design_and_engineering__wiki/17806.to-assign-filter-on-specific-property
Hope this helps.
Regards,Harpreet
Answer Verified By: Xiongfei Zhao
Rahul Kumar
Thank you! This is to inform you that this Service Request resulted in Enhancement Request #201515. We are keeping the status as Open Enhancement filed.
