I am trying to find cells that assumably would have been part of the cell library in OPPID out of the box. I am trying to find cells for things such as an air supply (attached) thermal weld, thermal couplling, pcv valve. I have been unable to find anything in the current library and am not sure if maybe they need added in along with other custom blocks that we typically use. Any help is greatly appreciated.
Another cell I have been unsuccesful in locating
Jeremy Grove
Mechanical Designer
YPS Johnson Controls
Jeremy, These cells graphically, are unique in someway to your company requirements. I have seen Air Supply graphically different from user to user. Same for the other cells. The PCV valves are in the system and are under Instruments. The cells that are not in the application will need to be created by you to meet your symbology. Tony DeRosa Bentley Plant
Tony DeRosa
Senior Application Engineer
Bentley Plant
