My company is using OpenPlant PowrPID, and we are trying to set things up to match our company standards. We need to make a few basic modifications to a few cells, such as the flow arrow size for minor and major pipe lines. How do we locate the actual cells in the library? How do we know what library to look into for which part? We are having difficulty viewing the cell library, which obviously must be dealt with before we even try to modify anything. Which leads me to our next issue. Is modifying a cell as simple as locating the cell in the cell library and modifying it from there?
Please help! And, obviously, a beginner like myself will need step-by-step guidance.
Thanks in advance!
Here is the link to Wiki where is a video about how to modify the size of Flow Arrows: communities.bentley.com/.../20231.how-do-modify-the-component-flow-arrow Alternative to identify a cell library in which cell is located you have to open Items browser and in items tree select your Component or Cell.
Other information about Cells you can find in Bentley OpenPlant PowerPID Help>PowerDraft Help>Getting Started>Cells.
Best Regards,Kestutis Mitkus
Application Engineer, Building, Structural & Plant
