OPPID v.427 - Data Manager Connected Line/Equipment Issue
Hello there,
Once I place an Instrument in OPPID and then synchronize the PID to Data Manager, this instrument works fine only if it is directly connected to the pipe run or equipment. However, if I want to place an instrument that contains an object as part of the Instrument (for example a magnetic flow meter or a control valve), or if this instrument is not directly connected to an equipment or pipe run (for example a flow transmitter connected to the magnetic flow meter, or DCS signals), the information related to Connected Line/Equipment cells on Data Manager doesn't appear. I have tried in both directions, creating tags on Data Manager and then synchronize to OPPID and creating the instrument on OPPID and then synchronize to Data Manager.
Hope someone can help me, thank you.
