We just recently upgraded to OPIM Version 08.11.09.458, in this new upgrade I noticed that when connecting to nozzles my dimensions are coming from the weld point between the flange and the pipe. We would like this dimension to come from the face of the flange. All other flanged connections are from face of flange.
To avail various component dimension, user could try Configuration settings, using configuration tools. Check options 'Dimensioning (1)' & 'Dimensioning(2)'. See image below:
See dimension below:
Also See Similar link discussed on same topic.
http://communities.bentley.com/products/plant/design___engineering/w/plant_design_and_engineering__wiki/20482.how-to-dimension-valve-with-gasket
You may attach an i model to investigate further.Please let us know.
Regards,Rahul Kumar
Rahul Kumar
Answer Verified By: Joey
Below are the path for default project folders:
For AutoPlant Users: C:\ProgramData\Bentley\Plant V8i\Bentley Plant V8i Projects\SAMPLE_METRIC\Config\OpenPlant\schemas For OpenPlant Users: C:\ProgramData\Bentley\OpenPlantModeler V8i\WorkSpace\Projects\OPModeler_Metric\DataSet\Schemas
It might help you to guide to your specific folders. Hope this helps here
