Hi, I am looking to annotate a piping GA using the AutoPLANT annotation tool. Question i have on BOP elavation annotation. How do i get it to g on one line rather than have it as two lines.
Hello Kfitz,
You can easily get display like above by turning off container and leader line. I guess you mean you are getting the annotation in two lines? Can you show a image showing annotation at your end? You can try to use below option to edit the text as you want.
By Using above option you will be prompted to edit the text as per your requirement. I hope this helps.
Dinesh Solanki
hi dinesh, stil lhaving problems with annotation preferences. Is there a setting to tell the annotation to come out in one line rather then two and my container box also is not coming in correctly. see below. it seems to leave out "-". the items i am picking have tags so I don't have to type anything.
For tag this is what i have for annotation setup
this is what i am getting.
this is what i want (had to manually edit above)
