I am looking for information on Cable Laying Method within BRCM, specifically, how do you route Single Layer cables?
Does BRCM know because of the cable type (i.e. 1/0, 4/0, 500, etc) that is should be in single layer tray, or do we need to manually specify this in the cable list that we import?
I am unsure of what BRCM's intent is to route different cable types.
Max Capacity applies regardless of the Cable Laying Method, I believe. For the Single Layer method, only half of the tray will be filled with a single layer if you set Max Capacity to 50%. So if you want the cable fill to be limited only by the Cable Laying Method, you would leave Max Capacity set to "<none>" or set it to "100%".
