Hi
Any ideas what I need to do to fix this sync error, am currently running the project database on my local c drive. one suggestion that has been made to me is there might be something wrong with the View Window (viewports) if this is the case any ideas how I can fix this.
Bentley.Plant.ModelingFramework.SQLPluginAdapter - Synchronization stopped because of error: 'SplitterDistance must be between Panel1MinSize and Width - Panel2MinSize.'.
Martyn
Tony DeRosa
Senior Application Engineer
Bentley Plant
Hi Tony, Martyn,
What was the outcome of this problem? We seem to have the same problem. Using OPPID 08.11.10.631 and with Plant Tools 08.11.12.111.
Alain
I just met same problem. And I have fixed it.
Open registry editor and go to [HKEY_CURRENT_USER\Software\Bentley\OpenPlantPID\Dialogs\Differencing]
check the value of the keys, some value are overflowed. For example, these ffff8300 are too big, change them to a reasonable value, like 223. Then it will be OK.
Answer Verified By: Rahul Kumar
Thanks Changsong Ling for participation here.
I hope this would help others fixing the problem.
-Regards | Rahul Kumar
Rahul Kumar
