Hi, I am running isometrics which have sloping pipe. This is an imperial units project on AutoPLANT SS4, v8i, on AutoCAD 2012. I have no problems showing slope ratio symbol on metric project but cannot get i to appear on imperial project. Attached is piping model. Can someon ehave a look and look at the opl file to see what i need to change.
KenSLOPE.zip
Thanks Jesse,
See attached
isogen.zip
Hello Ken,
Did you check option 19 in Option editor?
Dinesh Solanki
Hi ken, Also make sure you take note of the secondary switch just below the 6 options for the slope representation format. The other setting controls the minimum slope to be treated as a fall or slope. In your case, if that switch was set to 1 you would need at least a slope of 1/16" per foot in order for anything to show up. In my experience, oftentimes even a slope that should be represented may be overlooked by isogen if it is close to that threshold or below a slope of 1% (approximately 1/8" per foot). Try experimenting with those settings and lines with more obvious slopes to see if you can get it to come in.
