Is there a way to disable to the East / South Coordinates that show in OPIM?
I have a question reg. coordinates system in OPIM. In which file relation between North and Y-axis is set?
for different Iso styles we can see different iso rotation for the same pipeline...
You could try below wiki article for reference to set the different plant north by giving an angle say 90 deg to variable IE_PlantNorth
How to set Different PLANT North in OpenPlant Isometrics Manager Applies To Product(s): OpenPlant Isometrics Manager Version(s): 08.11.11.XXX (SS6) Environment: Windows 7/8.1/10 (64 bit) Area: Settings\Attributes Subarea: Style… Last edited over 7 years ago in OpenPlant | AutoPLANT > OpenPlant | AutoPLANT Wiki
HTH
Rahul Kumar
Actually, I did sth like this:
IE_PlantNorth = 0 0 0 0 ...
and it works...
originally it was blocked:
# IE_PlantNorth = 0 0 0 0
Thanks to confirm!
HTH,
