A client gave me several Autocad files of some industrial equipment and buildings to be brought into 3ds Max and rendered.
Upon opening the file in Autocad 2015 (or 2012) I get 7 errors effecting over 4000 objects causing them not to be visible, Missing Application: At_Reboids
After some googling I tried installing the AutoPlant object enabler and still no luck.
Any ideas or solutions would be greatly appreciated, I just need to be able to open the files export them to FBX.
-David
I
Hello Christine,
Thanks for your query. May I ask you for the configuration details you are looking for to avail the object enabler? If you are not able to download it from site, then in other possible case we can provide you the link to download it.
Also check below link to download it.
See option to check "Software Download"
If you are looking for specific problem that is causing it not to download, then I would suggest you to create a Service Request to get direct help from the Analyst.
-Regards | Rahul Kumar
P.S. - Unfortunately, Artiom is no longer associated with Bentley now.
Rahul Kumar
