I added a rule in overrides.txt file trying to place elbow and tee in Fittings level instead of defaul Level 1, but it does not work. Here is my rule for it.
RULEINCLUDE = IE_TYPE=CT_ELBOW || IE_TYPE=CT_FITTING_TEELEVEL NAME = Fittings
Please help
Maggie
Hello Maggie,
To add classes use single Pipe/vertical only. See below Expression you could try.
RULE
INCLUDE = IE_TYPE=CT_ELBOW|CT_FITTING_TEE
LEVELNAME = Fittings
Note - Levelname has not space in it.
Hope this helps. Please let us know
Regards,Rahul Kumar
Rahul Kumar
Support Manager – Global Technical Support | Community Moderator
Answer Verified By: Maggie Zhang
