Can anyone please explain what is going on here, how can one tell if the enabler is installed correctly on your computer dealing with AutoCAd 2015, two different people say I should see a tab in the option dialog box and I do not.
So one how do I know I have the correct enabler I need AutoPlant,
Once I have that how do I know if its installed correctly and autoCAD is reading the AutoPlant enabler
Hi George,
Thank you for your question. I will try to explain bi in details.
I usually check what ARX files are loaded. Type APPLOAD in AutoCAD command line and check what ARX files are loaded. AutoPlant related arx files has at_ prefix.
In case ARX files are not loaded check following:
Check if the options allow to load object ARX applications.
As well in case of AutoCAD 2015 check that the storage path of object enabler's arx files are added to Trusted Locations.
I hope this will help. Regards,
Artiom
This was a great help, but has I was looking at the bentley folder I notes this there is no AutoCAD 2015 folder in this enabler so now I am back to zero, can you send me the correct enabler please
Hello George,
The Object Enabler that is supported with AutoCAD 2015 is 08.11.12.111. Please download it from select.bentley.com/FulfillmentCenter
Select AutoPlant as Brand product and expand AutoPlant Modeler group for AutoPLANT Object Enabler V8i 08.11.12.111
I hope this will do.
Kind Regards,
