When running "Create Iso via OPIM", the component selection window is always set on "All". Can this be set base on user's last use, just like component selection in other command?
Can "Use Project Settings" be enabled such criteria can be controlled in central place instead of relying on designer?
I am using AutoPLANT 08.11.12.111 and OPIM 08.11.09.564
Maggie
Hello Maggie,
This is a known issue with AutoPLANT 08.11.12.111. Please follow the steps below to solve the problem.
1. Download Prerequisites and Common Tools for AutoPLANT Applications v8i x64 Update 1 (08.11.12.114). This software can be found in download section of our Bentley website
2. Run the patch
3. Verify the results
Dinesh
Answer Verified By: Maggie Zhang
G'day Dinesh
Has this been resolved yet, why isn't this setting available?
CheersSteve
