The current OPIM use same linetype and same linetype scale for both existing pipe and existing components. If linetype scale is big, existing components do not form a shape in print out; if the linetype scale is small, dashed pipe show almost like continued/solid line.
Is possible to have different linetype or scale for continued/existing pipe from continued/existing components?
Maggie
Hello Maggie,
This is possible with latest 08.11.09.564 version only. See example#2 discussed in wiki link refer below:
http://communities.bentley.com/products/plant/design___engineering/w/plant_design_and_engineering__wiki/23419.how-to-user-overrides-for-isometric-components
Hope this is a helpful information.
Regards | Rahul Kumar
Rahul Kumar
