When I ran ISO on a bleed ring with tap port, the tapping point show in middle of bleed ring symbol instead of edge of bleed right. Is any settings I can set to make it show properly?
Also why bleed ring show as Flange in Part ID? Can I split it from combo part ID and display like other fittings?
Maggie
Answer Verified By: Rajesh Agrawal
