I am trying to show valve operator spindle direction, but I cannot find the setting. I tried to enable valve operator label, but it only shows operator name, like "HAND_WHEEL" (expecting SPINDLE NORTH or SPINDLE UP, etc) . How and where can I do the setting?
Maggie
Hello Maggie,
Are you trying it with angle 90, 180 etc?. For angles other than 90, 180, you can get the orientation automatically. Please give a try on it. See image below.
You could also use user labels to get the Spindle word along with it, but only with non planar directions. See below settings:
To get the same on standard orientation like 90, 180 etc, you may create a Service request. We will take this with development guys.
-Regards | Rahul Kumar
Rahul Kumar
Thank you for creating Service Request 7000412009. We have filed an Enhancement # 187220 to get the plane angle details in OpenPlant Isometrics Manager.
On removing the Operator Name, we need to check and reply back soon.
This is still to be implemented but meanwhile you can refer below link as a workaround.
http://communities.bentley.com/products/plant/design___engineering/w/plant_design_and_engineering__wiki/24510.to-display-right-angle-operator-direction-with-spindle-in-openplant-isometrics-manager
Hope this helps!
Regards,Harpreet
