Is it possible to to place continued ISO number in second line just like continuation to nozzle?
Maggie
Hi Maggie,
Yes, it is possible.
1. You need to open OpenPlant_3D.01.04.ecschema.xml and supplement it with OpenPlant_3D_Supplemental_Isometrics_Isoextractor.01.04.ecschema.xml in Bnetley Class Editor.
2. Go to "Classes>Plant Base Object>Named item> Iso Sheet" and edit Continuation Expression custom attributes value. Add additional character $.
3. Close OPIM and Generate ISO again
Best Regards,Kestutis Mitkus Technical Support Group Bentley Systems Inc.
Product Engineer – Bentley Systems
Answer Verified By: Maggie Zhang
If you need to set this "Continuation expression" for connection label (CONN. TO) also, you can set it up on the "PIPING_NETWORK_SYSTEM" as follows: ":$" & this.NAME
