OpenPlant PowerPID V8i (SS5). Is there a setting that disables the hot points upon selecting an element within the drawing. I do not have hot points to manipulate process lines, equipment or anything for that matter. Not sure if there is a preference setting or possibly a schema setting that would disable this. Any help is appreciated TIA.
Hello Grover89,
This is controlled in the Element Selection dialog. Look at the images below. The Handles button (Disable Handles) button has two settings.
When it has a highlighted background as shown below, the handles are disabled.
When it does not have the highlighted background as shown below, the handles are enabled.
I hope this helps,
Tony DeRosa
Bentley Plant
Senior Application Engineer
