I am using OPPID Version, 08.11.10.631.
I want to edit some unwanted tags directly by multi-selection in plant project.
By default in the current version it is disabled, is it possible to enable this function?
Krishna Natkar.
Hi Harpreet,
Thanks for your reply,
Please also look to below issues, if you can help me in some way.
OPPID Service Error : deletion
http://communities.bentley.com/products/plant/design___engineering/f/5927/p/113153/347069#347069
OPPID : pid diagnostic checkforduplicateguids
http://communities.bentley.com/products/plant/design___engineering/f/5927/p/112674/344484#344484
Hi, i am having the "The Project Browser is disabled" issue in OPPID SS6. I´ve already checked for duplicated guids and found 2221 problems. All PID were made in OPPID SS6, but I think it might be because i made the mistake of editing the seed file with oppid instead of basic microstation. I´ve already made the pid model dissociate + pid model regenguid as explained in the forum and replaced the seed file with the backup file edited in the correct way, so i don't know why we still have duplicated guids.
Is the "The Project Browser is disabled" error related to the duplicated guids? How can i solve both issues?
Thanks in advance, Ignacio.
I found the solution for this issue copying the file to another directory, deleting the original, opening the copy and selecting "this file was copied" so as to obtain another PID Document GUID. Then i moved this copy to the correct path and selected "this file was moved" while opening it
