DISPLAY OF RATING ONTO REPORT IN OPIM
Greetings,
I cant get the Rating of either bolts, flanges, etc to appear on the report (bom), whist I can however get any field to appear.
I modified the class and report file as indicated in the OPIM help pages but it doesn't seem to work for Rating.
What should I call in the Report file to get the Rating to appear on the Report ?
Thank you very much for your help !
-Guy
  • Hello Guy,
    Thanks for your query!
    Could you please attach the report file to investigate it at our end? Defining RATING attribute should work like described in wiki pages.
    I would suggest you to create a Service Request and attach all the relevant details and files for further investigation.
    -Regards | Rahul Kumar
    Rahul Kumar
    Product Engineer – Global Technical Support | Community Moderator
  • Hi Rahul,
    It turns out that I had to close the Class Editor for every change I make within it.
    As long as I keep the Class Editor open, seems the changes don't apply.
    I closed both the Class Editor and the model, reopened the model, and so the miracle happened !
    Thanks for your help : )
    Guy
  • Hello Guy,
    Thanks to confirm.
    Yes, on every changes done in Schema, requires a proper closing of all running OpenPlant application. Sometimes user need to create a new i model as well to see the changes. This happens when modification has been done for ISO_SHEET class, then user need to create a new sheet to apply the changes in it.
    Also Changes done in files present in style folder, requires a regeneration of drawing only, without closing any application.
    Rahul Kumar
    Answer Verified By: Guy Guerin
Reply
  • Hello Guy,
    Thanks to confirm.
    Rahul Kumar
