I&W drawing problem
HI, I have a problem when I want to generate an loop drawing In the layout designer as you can see in the previous caption. When I do click on the preview button
I have the following errors:
  • Hi,
    As per my knowledge ,by looking at the error ,these might be causes for this error.
    1. please check in document Manager ->file->Viewer and file type set up. DGN is set to default open with Microstation.exe ( if you are using Microstation as Template generator) or /and DWG is set to open as default with AutoCAD 2014 Application.(if you are using AutoCAD as template Generator.
    2.AutoPLANT framework does not configured correctly to view document. i can say installation order may be not correct.
    installation order should be 1.MS Office 2.Microstation 3.AutoPLANT framework. 4. Bentley Instrumentation and Wiring.
    if you are using AutoCAD then ,in place of Microstation there AutoCAD can be installed.
