What modifications are required to the reports.def file to make the CUT LIST appear in two or more columns
I would like to have two columns of 6 rows to make up the CUT LIST.
Old SS4 (ISOGEN) version would have the following
CUT-LIST-OVERFLOW YESMAXIMUM-COLUMNS 2MAXIMUM-ROWS 6
Ray
Hello Ray,
Report.def file allow you to customize BOM report as desired. By Default 6 columns you will get in this file. You may comment the undesired column through a "#' sign or you may delete the column and write your own attribute you want to show here. See image below for a quick reference.
However Rows populates based on entries or grouping done based on CUTID. You may change the group from CUTID to other based on which you want to populate in list.
See one wiki below for your reference about sorting.
http://communities.bentley.com/products/plant/design___engineering/w/plant_design_and_engineering__wiki/19829.weld-summary-report-to-sum-up-the-welds-according-to-the-weld-type
Hope this helps! You may expect other expert comments relative to ISOGEN context.
-Regards | Rahul Kumar
Rahul Kumar
Hi Rahul,
Sorry I have not explained myself well here, what I need is to have the ability to set how many rows before a new table continuation for CUT_LIST.
In AutoPLANT SS4 (ISOGEN) the following lines would return the table below.
CUT-LIST-CONTROLSTABLE-LAYOUT VERTICALVERTICAL-TABLE-DIRECTION DOWNCUT-LIST-OVERFLOW YESHORIZONTAL-SPACING 86MAXIMUM-COLUMNS 2MAXIMUM-ROWS 4
Horizontal spacing was the distance between tablesMax columns being maximum number of whole table columns (not columns within the table)Max rows would be the number of rows before the next whole table was produced
PIPE A106 Gr B
I need to reproduce this in OPIM (AutoPLANT), currently I can only produce a list that looks like this
E 200 2297 PIPE A106 Gr B F 200 784 PIPE A106 Gr B G 200 1362 PIPE A106 Gr B H 200 121 PIPE A106 Gr B
Thanks for details explanation. This is loud and clear now. I believe you wont get any similar settings to organize the list by defining rows and column, exceeding which will create a new table adjacent to it in current version.
I would suggest you to please create a Service Request to get it evaluated by development team.
Based on Service Request SR # 7000446862, we have filed an Enhancement Request# 353866. which will further get evaluated by development team & Product Management Team. Submitting it for your information please.
