I now have AP-imodel composer installed and running in AutoPLANT Modeler SS7. When I bring up the Publish I-model pane and tell it to create a package it allows me to then change the name of the package.....
Accoording to the help file, the magnifying glass next to the package name is supposed to allow you to change the folder location. The button does not work for me. It actually just looks like a graphic and not a button at all.
Is there a setting to enable this button?
Hello Randall,
What exact version of AutoPLANT I model composer and AutoPLANT Version are you using? I tried with with same version on a machine i.e. 08.11.12.226 and it works well.
Dinesh
Dinesh,
I have AutoPLANT Modeler 8.11.12.226 installed
I have AP-Imodel composer 8.11.12.226 installed
My Publish I-model pane looks like this:
That button looks greyed out to me. When I try to click on it, it does not respond.....
Best Regards,Kestutis Mitkus
Application Engineer, Building, Structural & Plant
