Hi Bentley,
I'm facing with unconnected component problem. It only simple piping model with 3 pipes and 2 elbows, but it failed to generate isometric dwg.
Please refer photo attached. I view the production log, but i don't know how to analysed the error data stated in that log.
Please explain how to analyse that log data. Is there any reference note that i can refer if this error happen again for the other component such as flange, gasket, fastener & etc.
Hello Hasnuddin Yusof,
What version of AutoPLANT Modeler and OpenPlant Isometric Manager version you are using? Please run connectivity checker to see the disconnects as below. As well send the AUtoPLANT Model for testing.
RegardsDinesh
Hi bentley,
I'm using autoplant SS5. I have tried the "connectivity checker" but there also have error (refer photo)
There is one error that keep appear on screen (refer photo). Please help me settle these problems
Thank you
Hasnuddin
