Hi Bentley,
Which catalog and specs that i can get the pipe & fittings for jacketed piping?
HY
Hello Hasnuddin Yusof,
Jacketed Piping Specifications
For the first release to include the Jacketed Piping module, the Catalogs/Specs are limited. Only the following specs are available, and in limited sizes:
JP_MHS (metric) - Only 2 sizes available (50mm and 80mm).
The JP_MHS spec is created from the Metric Catalog (MHS.mdb) provided and should be modified using the Spec Generator application to contain the components that you will use on your projects.
Refer to the Spec Generator help for information on creating and modifying specs.
Non-Standard Specs (For Testing Purposes)
The install will also provide non-standard specs for all 3 units (Imperial, Metric, Mixed-Metric). These specs will be for testing various components for the Jacketed Piping module. The names of the non-standard specs are listed as:
JP_Non-standard (Imperial)
MJP_Non-standard (Metric)
MMJP_Non-Standard (Mixed-Metric)
Dinesh Solanki
