Text Note Editor_change text justification
Hi Bentley,
I'm using openplant isometric manager SS5. I'm trying to setup my own isometric dwg border.
I'm facing problem with text note editor which is to change text justification for text placement (refer photo)
How to change text justification for +60 (MTO), example from middle left to top left.
  • Hello Hasnuddin,
    Right click on +60 text node, then select Change Text Attributes
    Select small arrow on right side to expand more settings
    Mark Justification box and chose required Justification
    In this Bentley Communities Wiki you can find more information about how to modify text and annotations settings.
    http://communities.bentley.com/products/plant/design___engineering/w/plant_design_and_engineering__wiki/12638.modifying-text-and-annotation-settings
    I hope this information will be useful. Please let me know if you need additional help on this topic or if you have other concerns/questions.
    Kestutis Mitkus
    Best Regards,
    Kestutis Mitkus
    Application Engineer, Building, Structural & Plant
Reply
  • Hello Hasnuddin,
    Kestutis Mitkus
    Best Regards,
    Kestutis Mitkus
