Bentley AutoPLANT V8i P & ID - Assembly file location path
I am currently investigating how to build standard designs for P & ID's and wish to alter the storage location (not on my C: drive) so other Bentley CAD users can access these assemblies.
I have read in the Bentley help files that the file path location can be altered in P & ID/Preferences...unfortunately this is not active in my drop down list...does this preference have to be switched on elsewhere etc.
Any help appreciated.
Paul.
Parents Reply
  • Modification of the System path was said to be possible in the help files contained within the P & ID Module - if this is not the case and you can only modify the project location then I would not be able to give access to other Technicians. Keeping these Assemblies on my C: drive is not ideal as the hard drive can crash ...perhaps I should back these onto a CD ROM and will be able to replace in same location when new drive is fixed......
