Currently I deleted the report text node to remove material report but I cannot find the option/ switch to remove Part ID in the ISO image.
Is it a way to hide Part ID in Stress ISO?
Maggie
Hello Maggie,
To remove PARTID, one way is to rename the cell from lisocomp.cel list. It will be specific to stress style folder only.
Image with PARTID:
Rename PARTID:
Image without PARTID:
Hope it helps!
-Regards | Rahul Kumar
Rahul Kumar
Hi Vivek,
Yes there is. In rep_sortgroups.txt add a section (as high up as possible) that catches the components that shouldn't get a part ID. The below example would target supports. The SKIP = 1 tell OPIM to skip these
SORTGROUP = SKIP RULE = EC_CLASS=SUPPORT SKIP = 1
You can still report on the skipped items
Frank
Answer Verified By: Rahul Kumar
Just what i was looking for standalone OPIM. I wanted to avoid the partid on components with State = Existing (a custom value we added equivalent than "for demolition"). This worked precisely as expected! Thanks Frank!!
