I was wondering if anyone could point me in the direction of setting the color of my insulation in my compprop.ebs? I’m looking to set it to bylayer (not force the color) and to match the piping layer color I have set (bylayer as well). I am using color "By Service" and layer "By number".
The color is currently it is being set to “0” and the insulation is being placed on a separate layer called <Linenumber> + "_Ins". See attached COMPPROP.ebs.
4370.COMPPROP.zip
Thanks in advance,
Dan
Currently using
AutoPLANT Modeler Version 8.11.12.111
AutoCAD 2015, x64
Hi Keith,
Thanks for answering, but this did not change the color of the insulation at all. It was working in version SS3, but after that it does not. Something changed in the code and I cannot find it. Let me know if you have any other ideas.
The color of insulation can now be set in the config.ini
Steps:
Joey,
Thanks for the reply. I have set the color to bylayer in the config.ini already. This does not answer my question.
Insulation_Color = BYLAYER
