I successfully modified the Schema to map Autoplant Spool ID to OPIM. However, the OPIM output Isometric puts a Spool Label on each and every component.
I only require one SPOOL Label at the beginning of the pipe run.
Is there a way to achieve this?
I've attached a screenshot showing all the Spool Labels and another showing how I really need it to look.
This is what I want:
Hi Stephen,
Check your Isometric styles Pipe Spool Label configuration.
Flags: Define S to make the label spool aware, i.e. only one label will be placed per spool. (Not one label per component.) Define P for PIPE cut labels.
In this wiki article you can find much more information about User Labels creation and configuration:http://communities.bentley.com/products/plant/design___engineering/w/plant_design_and_engineering__wiki/12638.modifying-text-and-annotation-settings
Hope this helps you
Regards,Kestutis Mitkus
Best Regards,Kestutis Mitkus
Application Engineer, Building, Structural & Plant
Answer Verified By: Rahul Kumar
Stephen Wood-Davies
Senior Designer / Bentley CAD Administrator
