Hi,I would like to split raceways in a project to three DGN files. For example in file LV ROOM_01.dgn I have outcoming raceways from switchgears and in a file LV ROOM_02.dgn I prepare incoming raceways to other switchgears. And in third file MAIN.dgn I would like to connect raceways (fill air gaps in a place when raceways are coming thru the fire wall). I use to do that function RACEWAY ROUTER->Cable routes->Generic Virtual Connection. Then I would like to route cables between two switchgears: in file ROUTING.dgn when I use option Routing Manager->Automatic Routing, I receive failure "No route found". I have already changed entry points, all cable ladders options are similar (multilayer, LV type) etc. The problem is with connection of raceways, because if I copy all cable ladders to one raceway file, and use virtual connection in this same way, it works. Any solution for that issue?
Hi Matuesz. To connect raceway to raceway in a referenced file, you must use the Raceway Router tool to draw an air gap route in both files so the air gap cable routes meet end-to-end.
Well, the BRCM-LVG is a folder available for each user with an account. The thing is, that the access to the folder is very limited, so I don't think you can lose precious information because of that, but still, if you want to delete it, you need to uncheck the required boxes in the Sharing panel, this will allow to remove this sharing feature. For more information about this , check this article https://osxtips.net/how-to-fix-brcm-lvg-under-shared-section-in-macos/ . Hope I gave you an answer and it will help you
