I need to generate a piping report BOM for our purchasing department and while all the other info is present, unfortunately the stud bolt size, diameter and length does not appear.
I find this strange as the stud bolt info is present and clear on all Iso's generated with OPIM.
How do I remedy this situation?
Cheers,
Steve
Hello Steve,
It should report size for each components & fasteners. Can you check report.def file if SIZE has been defined or not commented?
Can you attach report.def file for our reference please.
-Regards | Rahul Kumar
Rahul Kumar
Hello Stephan,
Could you please check with unit imperial or mixed metric.
Also please set the the correct values for Precision and Bore Precision.
Looking forward to your reply.
Abhijit Bute
Answer Verified By: Rajesh Agrawal
Stephen Wood-Davies
Senior Designer / Bentley CAD Administrator
Finally got it working, thanks for the advice. Had to add the Long Description in Project Administrator to the available fields under Reports, also BOLT_DIA & BOLT_LEN. Update components in the model, then generate the report using "Custom" & "Brief".
