Hi all,
i wanna integrate steam traps in my pipe class, but the schemas only have a Steam_trap class without any graphics information.
Can i integrate steam traps myself, like i copy the left properties and information from another class (mybe from any valve with main and run port) or any of the next OPM versions bring this ? (i use at the moment OPM version .568)
regards, Markus
Hello Markus,
You can integrate it. You can check Customize option present under "workspace" option. Also you can refer Help file for details using Customize keyword.
Hope it helps here.
-Regards | Rahul Kumar
Rahul Kumar
Answer Verified By: Markus Wilbers
Hello Marcus, Yes you can add a special button in the task panel with the help of this wiki:http://communities.bentley.com/products/plant/design___engineering/w/plant_design_and_engineering__wiki/28032.how-to-create-custom-component-s-tool-button-in-openplant-modeler-task-panel
As graphics for the Steam Trap in this wiki I have used Y-Strainer. Regards, Kestutis Mitkus
Best Regards,Kestutis Mitkus
Application Engineer, Building, Structural & Plant
Does anyone know if steam traps are also available for Openplant CE? Kestutis Mitkus In your wiki only V8i Version will be named. Is there the same option for CE version?
Dear Markus,
For CONNECT Edition, Ribbon tools introduced where you can add the icons for your custom components.
we will add the details and share separate wiki for it.
HTH,
