Hi everone,
i had see that different gauge typs are in the OPM schemas, but i can't find a way to place this different gauge types im OpenPlant Modeler.
The only gauges i find in OPM are the "generic gauges"
The following i can find in the schemas:
Yeah, thats helps me ;D
sry i had say this more clear i dont want different graphics in OPM i want difference symbols on the isometric, and with the solution from Kumar i had difference classes with difference symbols in the isometric.
Thanks all, i rly like this forum.
Thanks to confirm Markus,
I should have written that. As Gaurav Mentioned, sometimes for any sub classes if you need different graphical symbol (with different ports etc), then component scripting part required if it is not available. You can request it from Bentley Professional Services team to do it for you.
We will try to document it to make it available for others.
-Regards | Rahul Kumar
Rahul Kumar
Have i any option to integrate the IE_Divice_Type Code and the Number of the gauges in the graphic like this :
So i dont want the Tag Name and the number not as Label, i want it integrate direct in the symbol of the gauges.
Hello Markus,
Yes you can do it. Instrument cell is present inside the template MISC.DGN. Where you can modify the changes. See below wiki for reference. http://communities.bentley.com/products/plant/design___engineering/w/plant_design_and_engineering__wiki/27950.how-to-use-custom-cell-as-user-labels-for-instrument-symbol
I hope it helps!
Answer Verified By: Markus Wilbers
