Our clients ask to provide IFC file for final deliverable for pumping stations. Is there any way to export OPM model to IFC file format with attributes?
Thanks in advances,
OhSung
Hello Ohsung,
Which version you are checking? Can you please provide some more details?
-Regards | Rahul Kumar
Rahul Kumar
Thanks Harpreet!
Yes there is an existing enhancement to it.
As IFC is different format, you may check it by opening with different applications and then exporting it to IFC. But Yes there is no direct import/Export right now.
Has something changed in this topic? It is currently possible to export from OPM to IFC file?
