Our clients ask to provide IFC file for final deliverable for pumping stations. Is there any way to export OPM model to IFC file format with attributes?
Thanks in advances,
OhSung
Hello Tomasz,
Thanks for your query on Plant Forum!
Yes IFC v4 is supported with SS6 version. you can check readme files under what's new section.
HTH,
-Regards | Rahul KumarProduct Engineer - Bentley SystemsAre you a CONNECTED User? Click here to find out more.
Find out whats inside Connect Advisor Update 2. Click here
Produce 3D models of existing conditions and Bring them to life!!
Rahul Kumar
Hello Rahu,
the question is whether it can be exported to IFC?
Hi Tomasz,
Currently we can't export to IFC.
Regards,Rajesh Agrawal
When?
Just following up on this Enhancement that has been alive from what I read below for over 3 years.
When will OPM have the capacity to export IFC files as a deliverable as per the original question?
