In Isometrics for AutoCad2015 I am unable to configure the Bill of Materials. I have recently upgraded. An "unhandles exception" window appears stating "Exception in AT_REPORT_SHOWOPTIONSANDCONFIGURE ARX" and system shuts down
Thanks Rajesh for responding. We are running AutoPlant Modeler for AutoCad 2015 and Isometrics for AutoCad 2015. Firstly, I should have mentioned that when I run initial ISO I am asked to load bomdwgs.scr as per snapshot. The second snapshot is the window which appears when I try and configure BOM.
1. Regarding file loading security concern message. Please refer Readme file under Known issues section. See below image for reference.
Please refer readme file from below Link:
http://communities.bentley.com/products/plant/design___engineering/m/plant_design_and_engineering_files/271327
2. About second problem i am able to reproduce with AutoPLANT Isometrics SS7 version 08.11.12.226/ 235 and i believe you are using same version.
Can you please create service request so that i can log defect for it.
Regards,Abhijit Bute
