Plantwise SS6 <> OpenPlant Model Server?
Some years back there was talk of 'Consensus Models' and extending OPMS to cover more Bentley applications instead of relying on read-only formats like i-models.
If I understood correctly, Plantwise and AXSYS saved to a separate database not OPMS repository. Is this still the case with SS6? If not, is this on the roadmap?
I would have thought that Plantwise's rules-based generative design and AXSYS simulation interface would be key to rounding out OpenPlant as a design tool by providing that all important FEED, where so much of the cost and performance of the design is defined.
The rules-based routing would be also be useful during the post-FEED stages. See GenMEP, which uses rules-based routing to ensure clash free layouts. Kind of annoying to see them market their product as cutting edge when Plantwise / D++ was probably doing this sort of thing in the plant and process world for decades.
  • Plantwise and ASXYS are not integrated with OpenPlant ModelServer SS6. There is a common database project currently underway and future integration plans are on the roadmap. We are planning to conduct a webinar on plant roadmap items (July-August timeframe) and I will make sure, information related to your query is explained in it when we talk about our next steps for OpenPlant.
    Abbas
  • Thanks for the update. I just had a look at Explore the Possibilities with Conceptual Plant Design which goes into the Plantwise SS6 new features.
    There is a section in the back end of the presentation, where the user is shown how to copy the Plantwise elements into a dgn file and DROP the pipes generated in Plantwise so that their centrelines can be used to MANUALLY re-create the pipes in OpenPlant.
    I hope that this kind of jerry-rigged low levels of interoperability will be corrected soon.
    There seems to be a pattern set over the years:
    1. Distributed Dgn's: Or the old Design History. First step of the ladder. The problem was that only the geometry was tracked. The parametric and non-graphic info was not tracked very well or at all. No schemas so I suppose tracking non-graphic data and how that data is handled/constrained would be pretty problematic.
    2. I-models: Each app writes an exporter to convert its internal data into ECFramework schemas that get attached to the i.dgn on export. Read-only which is helpful for information consumers like compliance checkers or programme monitors or estimators but NOT really very helpful for the producers of the information.
    3. ISM: Each app writes a synchroniser plugin to write as read information from a centralised 'database'. Since the external app's tools are not available, the native app's tools would need to run when the incoming changes are synchronised from the ISM. Transaction management and mapping/healing settings stored with the ISM. You see demos of ISM where a wall or beam can be moved in a design or analysis or detailing app, and the changes re-enacted in the other apps on synchronisation. I guess that by providing schemas, common elements like the beam end points etc gets 'type-checked' before hand and optimises the translation process. Great, but there is still a lag or barrier.
    4. Multi-disciplinary 'suite' apps: OpenPlant and ABD have multiple toolsets that can be loaded in the same session. When a structural member needs to be moved to make way for mech ducts or pipes or electrical trunking etc, the tools are available to handle the different schemas in the same session. No ISM etc required as the tools write to their own data attachments (ABD) or a centralised DB (OP). But there will still be lots of external apps to deal with... coming up the 'interoperability ladder'.
    5. SMC: OpenPlant SS6 now includes some common Structural Modeling Components, which also includes a grid tool that is common to ProStructures and ABD. Maybe there will also be common piping, ducting and electrical modeling components soon?
    ProjectWise and Connect is about providing a Common Data Environment (CDE), Mstn CE Functional Components is supposed to provide a Common Modeling Environment. Some of the newer Bentley apps like OpenBridge Modeler seem to be able to incorporate schemas and modeling tools from other apps. In the case of OBM, the user has tools to modify the roadway alignment (OpenRoads?) and closely integrated with LEAP/RM analysis packages. Minecycle seems to incorporate ConstructSim and PowerCivils functionality.
    Maybe, some day all Bentley products will have the same level of interoperability as Catia has with its Workbenches. Instead of developing a structural or electrical tool without any thought about interoperability, the SDK should force the developer to develop the tool as a 'common component' from the start, to be portable and able to contribute as part of a CONNECT'd PowerPlatform.
  • Thank you very much for your post. I appreciate all the time you put into your thoughts. Having passionate users such as yourself will only help us make our products better.
    Integration between AXSYS and PlantWise and OpenPlant Model Server as Abbas noted is not something that is on the backlog at the moment because we are now working on a common database project that we think will be very exciting news for everyone in the roadmap webinar that we will be presenting this summer. At that time we will be discussing not only the work on the individual applications, but how we will be handling interoperability between not only our Plant products, but also applications in other verticals as well.
    On your point on Common Modeling Environment, we have a number of users who have spoken with us about their vision of a Common Modeling Environment and I would be happy to discuss this with you as well. Please feel free to reach out to me anytime with your thoughts or questions.
    Rob
    Director of Product Management - Bentley Plant Design
