In OPIM, when extracting isometrics with angled lines, the program puts in two dimension lines with a small square in the corner to show that this is an angled line. The cell for this square is called Dimbox. This cell is so small that it's hardly noticeable on the isometrics. I can't find the cell in our isometric library so I assume it's hard coded into the program.
Is there any way to modify this box so I can adjust the size of the cell for all of our isometrics?
Hi Richard,
In OPIM configuration manager select Rolling Offset Depiction.
Symbol size configures the size in millimeters of the right angle indicator
Frank
Hello Richard,
You will find this setting in OpenPlant Isometric Manager (08.11.11.87) in Isometric configuaration.
Hope this helps. Looking forward to your reply.
Abhijit Bute
As Suggested here, you can opt various option under isometric Configuration dialog. But this is readily available from 08.11.11.87 version. However, you can change the settings in style.xml file for SS5 08.11.09.574 version.
We have created one wiki for ready reference for mentioning both ways for SS5 & SS6.
http://communities.bentley.com/products/plant/design___engineering/w/plant_design_and_engineering__wiki/29275.how-to-use-various-rolling-offset-options-in-openplant-isometrics-manager
HTH
-Regards | Rahul Kumar
Rahul Kumar
