Hi bentley,
I'm using autoplant SS5. I find out my pipe spec nominal size is blank (refer photo)
Why this happened? How to solve this problem?
Thank you.
H.Y
Hello Hasnuddin,
Are they coming for all Size/Spec etc?
-Regards | Rahul Kumar
Rahul Kumar
Hello Hasnuddin Yusof,
Could you please try following steps:
1. Open Specification Generator.
2. Select your project.
3. Ad select existing spec option.
4. Select spec "Mmcs150.mdb"
5. Build spec by selection following option
6. Once spec build process finish. open AutoPLANT drawing select spec Mmcs150 and check the sizes.
7. Same steps need to do with spec "Mm_jis_jpi.mdb".
Hope this helps. Looking forward to your reply.
Moreover you can refer follow Link regarding SpecGen overview
http://communities.bentley.com/products/plant/design___engineering/b/plant_design_and_engineering_blog/archive/2010/06/08/using-specgen-v8i
Abhijit Bute
Answer Verified By: Abhijit Bute
