Can pipe symbol be LineString/Shape instead of just Line? The problem is we use CTB files to plot which line weight relies on color, especially for simple line, while plotting, line weigh is ignored. For other components, I can change in cell library by myself, but pipe is automatically drawn by system.
Is it a way to control it?
Maggie
Hello Maggie,
You can change line colour as per your requirment in isometric configuration refer below image:
Also you can control this setting by "override.txt" file. for more details refer following link:
http://communities.bentley.com/products/plant/design___engineering/w/plant_design_and_engineering__wiki/23419.how-to-user-overrides-for-isometric-components
Hope this helps. Looking forward to your reply.
Abhijit Bute
