How do I disable the dimension on the existing part? I tried to add a rule in the OverRides.txt file but keep having them:
#Existing parts are not dimensionedRULEINCLUDE=COMP_STATE=FOR_DEMOLITIONDIMENSION=0
Hello Stephane,
Refer below wiki article under section AutoPLANT Modeler - OpenPlant Isometrics Manager from Step 6 - 9
http://communities.bentley.com/products/plant/design___engineering/w/plant_design_and_engineering__wiki/30414.how-to-adjust-field-fit-weld-or-existing-dimensions-in-isometrics
I Hope this helps here.
-Regards | Rahul Kumar
Rahul Kumar
Answer Verified By: S. Hotte
