HI,
I'm investigating OpenPlant Isometric Manager for our workflow and at this stage, I have a lot of questions. To start off, it seems OPIM only uses untitled user preferences/interface. Can that be changed?
And that leads to a broader question, can OPIM be admin-ed similarly to OP Modeller? as in customised network workspace with customised folder structure for Projects, Users, Interfaces etc.
I can see and extract the list of config variable of the OpenPlantIsoExtractor.exe so that's all good. But the step going from Bentley.Isometrics.App.exe to select the project and to launch OpenPlantIsoExtractor.exe is where I'm stuck at the moment.
My plan is to have OPM and OPIM run off a single networked workspace with our company customised folder structures. Is it something achievable?
Best regards,
Tuan
Hi Tuan,
Yes, you can change the user as per requirement and you can put your OpenPlant Modeler workspace in a network drive and let OpenPlant Isometrics Manager read that. Below are some wiki articles which should help you in this case.
http://communities.bentley.com/products/plant/design___engineering/w/plant_design_and_engineering__wiki/27839.how-to-point-to-shared-workspace-of-openplant-modeler
http://communities.bentley.com/products/plant/design___engineering/w/plant_design_and_engineering__wiki/30440.unable-to-launch-openplant-isometrics-manager
Hope this helps!
Regards,Harpreet
