I have an issue with a specific file that I have been using, recently it gave me an error (below).
I would like to remove this error from the file. I have made a copy of the file on my c:drive and deleted everything in the file as well as all the pipeline tags that were created and the error still persists. Is there something else I can try to get rid of this error? File included... hopefully it can be viewed.
Kind Regards,
Shaun R
8712.H350997-0000-250-20M-0001.dgn
Hi Shaun,
This generally happens when you have duplicate Segments in the model. Please refer below wiki article to resolve the issue.
http://communities.bentley.com/products/plant/design___engineering/w/plant_design_and_engineering__wiki/24435.error-message-on-opening-existing-models-in-08-11-09-564-build
Hope this helps!
Regards,Harpreet
Answer Verified By: Shaun Raymond
HI Harpreet This link is not working. Can you please provide an updated link? Thanks
