Hello, Bentley team!
I have a question about custom equipment in OpenPlant Modeler. How can I add a new equipment geometrical types( like cubic tanks) to already existing equipment in OpenPlant Modeler or even create a brand new custom equipment model and add it to OpenPlant Modeler equipment list ?
Hope for your quick answer!Regards
Hello Yurii,
Thanks for posting your query on forum.
Creating custom as a fundamental approach can be found inside help file menu. You can search with logical keywords. See image below for your reference.
Also for using various existing equipment and modifying it as per requirement can be done by dropping it in OpenPlant Modeler. See below wiki for your reference.
http://communities.bentley.com/products/plant/design___engineering/w/plant_design_and_engineering__wiki/24259.how-to-update-graphics-of-custom-equipment-in-openplant-modeler
http://communities.bentley.com/products/plant/design___engineering/w/plant_design_and_engineering__wiki/27174.how-to-deal-with-custom-equipment-created-from-shared-cells
You can also check other relevant wikis under Plant group for your help.
HTH
-Regards | Rahul Kumar
Rahul Kumar
