Hello.
I've got pipe model made in OpenPlant Modeler which is underground, and terrain model from Inroads. I need to generate profiles consist of chainage, ground elevation and invert levels, everything on the table below profile. I tried to get 3d centerline axis and treat it as alignment, then make annotation. But I need line which represents invert levels. I tried to drop solid and get line from the bottom of pipe, but it makes it quite complicated. Does anybody know how to do it in the easiest way? Any suggestion or another way to generate profile as I mentioned?
Hi Serrgius,
Are you trying to generate profiles in OpenPlant Modeler? Could you please provide some details with snapshots?
Regards,Harpreet
I mean, I know how generate and annotate dtm profile, but I need also profile of my pipe, to put it together with annotation consist of invert levels.
Do you have any ideas how to extract profiles of pipes and then generate values of inverts, ?
I will add some snapshots tomorrow.
