Can anyone tell me how to share a Project that is sitting on the Company Network.
It has been created Using OPModeller_Metric as the base and then a new Workspace & Project created onto the company Network using the Modified OPModeller_Metric Project
How do we share the Local company Network Project between 2 or 3 Users on the network, without using ProjectWise.
Any Suggestions or solutions would be greatly appreciated.
Hi Colin,
Please refer below wiki article for sharing the OpenPlant Modeler workspace on network drive.
http://communities.bentley.com/products/plant/design___engineering/w/plant_design_and_engineering__wiki/28289.how-to-configure-openplant-modeler-to-use-workspace-from-shared-location
Similarly, you will need to make changes in config file of OpenPlant Isometric Manager. Please refer below wiki article for that.http://communities.bentley.com/products/plant/design___engineering/w/plant_design_and_engineering__wiki/27839.how-to-point-to-shared-workspace-of-openplant-modeler
Hope this helps!
Regards,Harpreet
