How can you show tracing on a Pipe in OPM and then have it show in OPIM?
I can see how Insulation works, but I can't see tracing apart from a value under Operating Conditions of the Pipe Line in Pipeline Manager.
I need the ability to specify the type of tracing and have it show in the OPIM.
Similar to this..
communities.bentley.com/.../12879.how-to-show-tracing-in-isometrics-using-autoisogen
Hello Ray,
There is a known Enhancement to implement the tracing feature inside OpenPlant Modeler. I would like to request you to create a service request on this, to enable us to prioritize the matter and to discuss it with product management team.
HTH
-Regards | Rahul Kumar
PS - Also check latest SS6 -What's New for OpenPlant Isometrics Manager for reference
http://communities.bentley.com/products/plant/design___engineering/w/plant_design_and_engineering__wiki/28553.what-s-new-selectseries-6
Rahul Kumar
Thanks Ray,
We have logged an Enhancement # 382891 based on SR # 7000562506 you have logged. This will further gets evaluated by product management team.
9 months on has this been added to OPIM?
