How can the OPM model name be shown on the OPIM Isometrics as an automatic field?
This would need to be written out as part of the imodel and then linked to a TAG in the OPIM style, but I'm unsure how to do this.
You would like to populate model name on EC Property and then assign it to TAG and further add it on isometric drawing output? There has been discussions in the past regarding this in below thread but I believe it is not possible in OpenPlant Modeler/Isometrics Manager.http://communities.bentley.com/products/plant/design___engineering/f/5927/t/119758
Regards,Harpreet
Hello Ray,
Check below wiki for reference. You can use drawing name to populate on isosheet.
http://communities.bentley.com/products/plant/design___engineering/w/plant_design_and_engineering__wiki/22211.to-change-isometric-output-drawing-name-format
Also let me know where you need to populate in drawing with some sample or images.
HTH,-Regards | Rahul Kumar
Rahul Kumar
Thanks Ray,
We will evaluate this & let you know.
